RCU Forums - View Single Post - Mid-Star 40 build
Old 11-16-2004 | 09:23 AM
Nebbie
Default RE: Mid-Star 40 build
Last nights progress (sorry, no pictures at this time):
1. Right wing: Glued on top trailing edge sheeting. Glued on top main spar. Glued on leading edge. Glued on top 3/32" front spar (which I broke while pinning it to the ribs and had to repair). Those spars sure are delicate!
2. Fuselage: Drilled holes in firewall for fuel lines. Fit in Sullivan 10oz tank (had to heat it up and flatten the back of the tank so it will fit).
3. Left wing: Whittled 1/4" trailing edge piece to be in line with top trailing edge sheeting.
4. Wing tips: I had glued the wing tips together upside down. So I had to cut them apart and reglue them together again. The wing tips are supposed to angle up when viewed from the rear. Mine were angled down. I just didn't pay enough attention when putting them together. [:@] So they were reglued and set aside.
TODO for tonight:
1. Glue wing tip to left wing.
2. Glue center sheeting to top of right wing.
3. Start working more on tail feathers. First will be sanding the elevators and fitting the connecting rod.
4. Take more pictures
