RE: I'm getting interference!
I had a similar problem several years ago, although it only showed up in flite. I eventually traced the cause to the spring type connectors for the crystal to plug into had loosened up, and under the in-air vibration created problems. Apparently, when the plane was restrained on the ground, there was enough dampening of vibration that the problem didn't show up.
