Aileron differential???
Arrrg.
"The wing is at 0 degrees aoa and is producing 0 lift."
AND
"Aileron diff does not reverse when you are inverted."
Is not consistent. It's all about the angle of attack relative to the differential ratio (up aileron/down aileron). The angle of attack upright is not the same as inverted but the differential ratio is.
I understand, and agree, with the first part, but the last part lost me. Of course you use the same rudder to counter adverse yaw when inverted but you need a lot more because the aileron differential is actually making the adverse yaw worse when inverted. Again, think about the angle of attack.
