RCU Forums - View Single Post - wing sheeting
Old 11-16-2004 | 10:39 PM
miamiflyer
Default RE: wing sheeting
thanks everyone, the edgegluing went fine using sigment and was
really easy to sand.
I'm on to glue the skin to the wing now and read the destructions again.
it says there to do that in two stages.
quote: "glue the wing skin sheeting in place on top of the spar and against the notch in the rib.
when the glue has cured apply a bead of glue to the top of each rib and along the sub LE.
Pull the sheeting down making sure it contacts the surface of each rib and the sub LE. hold in place until glue has cured."
Huh? why not glue that in one step? what if there is too much glue sqeezed on and prevents pulling it down to contact all the ribs?
confused. [&o]
