RE: wing sheeting
because the sheeting is less likely to stay flat on the spar if you try to do it all at once. The instructions are correct. That's the best way to do it. It helps if you have a syringe to put glue in. If not, pour some glue in a small container and use a small stick of balsa or a bamboo skewer to put the glue on the ribs rather than trying to fit a big bottle in there.
