RE: I'm getting interference!
I would suspect a loose connection caused by the vibration. It sounds like it may be a loose crystal in the rx or a loose connection in the power switch. It could also be a bad connection where the antennae is soldered to the circuit board. Let is know what you find because you know we will all check it on our planes.
