1/4 Giles wing failure x2
Are all you guys with wing failures and cracks using gas engines? Are you using a soft mount for the engine? If you are using a gas engine without a soft mount that could be most of your problem. The fibration from the engine just may be to much for this plane. After all the recomended engine is a OS 1.60. Just my thought.
