RCU Forums - View Single Post - WING DESIGN
Thread: WING DESIGN
Old 11-17-2004 | 01:46 AM
BMatthews's Avatar
BMatthews
Default RE: WING DESIGN
OH! You mean the pitching moment of the wing. Yes, your model WILL require some negative incidence in the stab compared to the wing. There's no need to sweat bullets over it though. Make the tail angle about 3 degrees negative compared to the wing and then trim the elevator as needed to suit your final CG location.
There IS an explanation of how to use the pitching moment value to size the horizontal tail but I'm a bit rusty on that part. In any event you're working with a kit I gather so it's a moot point.
Your airfoil number isn't in Profili2's database. I think you may have the number mixed up...
And cwrr5 is trying to say that in internet newsgroup language typing in caps is like yelling and is considered impolite.
Good luck with your A10.
