RCU Forums - View Single Post - combustion chamber shape for diesel
Old 11-17-2004 | 09:51 AM
Jim Thomerson
Default combustion chamber shape for diesel
I've been told that because diesels are detonation engines (more properly spontaneous ignition) the shape of the combustion chamber is irrelevant. The RJL 40 head contrapiston has a shallow bubble and was said to idle better. When we replaced the contrapiston after it broke, the piece of aluminum we used happened to have a shallow cone in the center. Both contrapistons ran fine for my purpose, which does not include idling. Most diesels have either a flat crown piston and a flat contra piston, or a slight cone on the piston and a matching cone in the contrapiston. We know that combustion chamber shape is important in a glowplug engine because combustion originates at the glowplug. Any thoughts on diesel?
Jim
