RCU Forums - View Single Post - Installing SIG hinges
Old 11-17-2004 | 03:15 PM
campbec
Default RE: Installing SIG hinges
Hi Hancop,
If you arn't confident of centering the slots there are a variety of tools from different manufacturers that provide a mechanical means of centering the slots on the fixed and movable surfaces. These kits usually have different sized two pronged forks to make the slot and a pick to remove the material to allow the hinge to slide in. Check out your LHS or on line cattle dogs. Don't forget to pin the hinges
