RCU Forums - View Single Post - Engine Mounting Question
Old 11-17-2004 | 07:45 PM
britbrat
Default RE: Engine Mounting Question
If you can fit the engine between the bearers, & they aren't bent in order to do it, you are probably OK. If you have to bend the bearers, they will fracture at some inconvenient time & the engine will be a bit loose (maybe fall out).
You can grind a bit away from the inside of the bearers to make it fit -- that is much better than forcing it in.
