RCU Forums - View Single Post - OS61FX four stroke equivalent
Old 08-19-2002 | 12:28 PM
rajul's Avatar
rajul
Moderator
My Feedback: (58)
Default OS61FX four stroke equivalent
Originally posted by w8ye
You asked about the reason for the pump and that is for an airplane where you cannot achieve good tank placement or you want the tank on the cg. It will even out the fuel flow where the engine run the same inverted or not and straight up, down, or level. Generally you don't need this on a 4 *.
Hi w8, if I were to get one without pump, will it be upgradable in the future, or will I have to get a standalone pump ?
Also, Terell mentioned about the OS91FS. What is the equivalent engine for Saito and YS ? Which is better in your opinion, in terms of power, user friendliness and maintenance ?
Will I need a stronger fuel tank as I heard about tanks bursting. Why do 4C engines generate so much tank pressure compared to 2C ?
On the subject of hovering, is this normally done with a 2C or 4C ?
Sorry for my inquisitiveness but thx in advance !...........
