RE: Funtana Conversion Battery Question
Bhouin
My caps lock was stuck on. This is better. I usually weigh my planes at the post office, but this one is too big. I used a fish scale but it seems to say all my planes weigh 5 lbs.
Do you mind if I post some more Construction photos on your thread? I like the way your cooling system works. I will probably make a side air scoop because I don't have the tools to make the cuts in the thicker fire wall wood like you did.
I am using HS 81MG servos every where except the elevator which has a standard one. I am not getting the throws I want. What did you use?
