RCU Forums - View Single Post - Jetcat glow plug problem
Old 11-17-2004 | 10:58 PM
siclick33
Default RE: Jetcat glow plug problem
The info that I have is that the ECU version is fine in 35Mhz as used in the UK. I have listened to the comments regarding the plug type but I think that if you turn down the voltage on the ECU then any plug should glow without failing,
I think that either I am dong something wrong or there is a fault somewhere.
