RCU Forums - View Single Post - We spend so much time ensuring that the props......
Old 11-18-2004 | 09:17 PM
Rudeboy's Avatar
Rudeboy
Default RE: We spend so much time ensuring that the props......
ORIGINAL: cwrr5
Curious - How do you balance your spinner?
First you balance the backplate alone. It should require very little if any balancing, especially on alu spinners with machined backplates. If you have to drill a "series" of holes something is really out of whack. Check if the shaft hole is properly centered. I wouldn't use a spinner that has visual runout.
After the backplate is balanced properly, put on the cone, and rebalance the assembly. You can do this by removing material, or by adding material, or both. Adding material can be as little as a couple of drops of CA inside the cone, one the light side.
