91FX problems.
I cut the needle valve assembly off the backplate, and mounted it on the firewall. And hey presto, no more bubbles, the engine gives consistant runs and there is very little vibration. The only thing is does that I don't like, is it hunts when you cut the throttle back to idle when flying. It doesn't apear to do it on the ground. Could this be something to do with the idle mixture?
Thanks Greg
