os 91 fx
This engine seems to run hot, which aggravates the problem of heat transfer into the needle valve body. OS has even changed the prop recommendations for this engine to smaller props, which will allow it to run at higher RPMs and presumably cooler temperatures. I noticed that the engine runs hotter with the baffle in the muffler. If you are having bubble problems, you may want to remove the baffle. The engine will be a little louder.
