RE: sig four star kit questions
One rib bay shorter? Shouldn't be a problem for a second plane.... of course, the other way of looking at it is, can the rib be glued back together and used anyway? Do you have a rib you can use as a template?...it would be pretty easy to cut one rib from a sheet of balsa.
