RCU Forums - View Single Post - Does the lst sliipper make a noise?
Old 11-20-2004 | 09:11 AM
TheBull350
Default RE: Does the lst sliipper make a noise?
read my original post. they move the front washer from the passenger side to the driver's side (if you live in the us that is) :-)
if you look at the front of the truck: left to right
if you look at the rear of the truck: right to left
swap it and put the case together and see what it feels like and rotate the drive shaft, if it binds then swap it around.
