RCU Forums - View Single Post - Wing flutter
Thread: Wing flutter
Old 08-24-2002 | 09:42 PM
Topgun2mo's Avatar
Topgun2mo
My Feedback: (45)
Default Wing Structure
Are those composite wing structures hollow with the spars internal?
It seems if this is the case the glue joint at the spar becomes so much more important! With a balsa or foam structure wing, there are many more areas loads can be dispersed.(entire surface area of the foam or across ribs/spars
Mike
