RCU Forums - View Single Post - using a tack rag
Old 11-21-2004 | 08:29 AM
Strat2003
Default RE: using a tack rag
Here's a trick I learned from a furniture refinisher....instead of a commercial tack rag treated with whatever that goo is, you can make your own using a wad of cheesecloth with a little bit of polyurethane varnish worked into it. That way anything that's left behind is a finishing material and not some sort of wax or whatever.
Keep the rag stored in a ziplock bag between uses and it doesn't dry out for a very long time.
