RE: Building a Dynaflite Super Decathlon
Because I will be using fuctional struts, I had to improve on the strut mounts in the wing. The instructions say to only use a small block that will be mounted to rib W5 with a ply brace. However, I'm going to extend that and make a solid ply rail that will go from rib W5 to the other W5 rib.
