ORIGINAL: Rupurt
Does any one have any experience changing the bushs for needle bearings to run lower oil
Yes all BAD. The crank pin is not hard enough to run needle bearings on. The crank pin is hollow so if you turn it down to press a hardened sleeve on it breaks because its now to thin.
If you cut off the pin and machine the crank so you can press a a solid pin, the balance is off. MAYBE you could press in a hollow hardened pin but you would need a good machine shop to weld the pin and make sure it was STRAIGHT
