RCU Forums - View Single Post - Yellow P47 Build up
Old 11-22-2004 | 05:49 AM
  #106
heliraptor
Default RE: Yellow P47 Build up
Hi
I have now finished the wing mounting. In the end spaced the dowels 4" apart, (2" either side of the centre line).
What I did find is the earlier problem I had with the difference in wing dimensions showed up again in the mounting. I had to mount the wing very slightly off the centre line (join line) to account for the difference in length (one longer then the other).
After much measuring its all done now.
First coat of resin goes on today after a bit of sanding prep on both the wing and elevator.
Lee
