RCU Forums - View Single Post - Yellow P47 Build up
Old 11-22-2004 | 02:57 PM
  #107
heliraptor
Default RE: Yellow P47 Build up
Hi
Just finished the wing prep. I thought I would trial fit the belly pan prior to glassing it to get it roughly into shape.
Went on okay after a bit of trimming. Put the wing up to the fuse and the belly pan sits quite high at the front and the rear by about 2mm either end. This is only going to increase after glassing.
Anyone else notice this??
If so how did you get round it, the only way I can see is to get back sanding the wing (bottom) so it sits down a little [:@]
Cheers
Lee
