RCU Forums - View Single Post - VectorFlight Edge 540 servo choices
Old 11-22-2004 | 03:01 PM
bubbagates's Avatar
bubbagates
My Feedback: (32)
Default RE: VectorFlight Edge 540 servo choices
Thanks for the servo tips everyone. I just ordered Hitech 645mg for everything but the throttle. The engine is going to be a Saito 100 and will probably turn a 16x4 or 16x6 both APC. The plane has been ordered and in the usually good C/S from Vector they thanked me and are cutting the hinges for me.
It is great to see such great C/S from a company that obviously cares about the customer, not to mention their reputation which is a direct result of customer satisfaction.
Once I get started on this plane I will be posting pics following the build process and a video of the maiden and it getting tossed around a bit. I will then send all it to Vector along with all the suggested mods that I compiled from the many great posts on this plane.
Now for a couple of quick questions. I really would like to mount this Saito 100 inverted.
Can anyone that has a Saito mounted inverted let me know how the alignment of the tank centerline versus the needle valve worked out. I saw where all that was needed was to reposition 2 of the mounting blindnuts but I did not see a mention of tank position.
Is there enough room in the fuse to move the tank close to the CG. I do realize that a pump or regulator would be needed for the Saito and probably would not be a bad thing if I was to mount it inverted anyway.
This plane is being built for IMAC flying mainly and the occasional hover or very mild 3D.
