RE: Ready2 build advice needed
Do NOT sand the leading edge. There have been wing failures from people who sanded it smooth.
The plastic used in the Ready is 100% fuel proof. (On the other hand, it holds paint very well if you clean it first.)
Two aileron servos will allow you to use flaperons, which can be fun to experiment with. Otherwise a single servo will be fine.
Jim
