RCU Forums - View Single Post - 2oz tank 30 size 4-stroke how long can I fly?
Old 11-23-2004 | 02:53 PM
Dukester
My Feedback: (31)
Default RE: 2oz tank 30 size 4-stroke how long can I fly?
Take crashem's advice and do a real life check. Depending on prop, needle setting, etc run times will vary to anyone else's experience.
I have a hand crank pump and here's what I would do. Fill the tank, counting the cranks in. Start the engine and run wide open for 3 minutes. Stop the engine and refill tank counting number of cranks to fill it back up. Then just do the math.
10 cranks to fill
3 minutes of run wide open
5 cranks to refill
equals
6 minutes at wide open.
Now go ahead and fly with a 5 minute timer as you would normally fly. Refill it and count cranks again. Revise your flight times based on your actual fuel draw with normal typical flying style.
Duke
