RCU Forums - View Single Post - Seagull Decathlon ARF
Old 11-24-2004 | 10:47 AM
mrjbernard
Default RE: Seagull Decathlon ARF
ORIGINAL: Tram
mjbernard - So your happy with the performance on a 46 fx huh? I will be flying at 500' MSL and am debating 46 or 61 fx..
The .46 performance is "sufficient". Trying to fit a .61 into the plane will likely leave you with a lot of extra cutting/fitting, but would certainly improve performance. The main goal would be to be able to swing a larger prop to provide for the movement of more air around the large cowling. I would suggest trying a .72 or .82 four stroke (eg. Saito) and a 13X6 or so prop if you want to step up performance.
