RE: B.M.E. 50 heat problems?
Any engine will overheat if not installed properly. The BME is normal in this regard. Set up the cowl so air in and 2x air out. Remember too, that there is not a lot of air flow from the inner 1/2 of the prop so avoid hovering till the engine is broken-in.
