RE: crossing wires on a pull-pull seup (?)
Thanks, thats pretty much what Id figured.
With the power of todays servos, losses to friction will be minimal. We're losing more power by using larger than normal control horns on our servo's. Im not sure where I read it, but you loose a LOT of potential torque the further from the servo centre you get. I endeavouring to use standard servo horn spacing but will probably need to go a size up.
