RE: wing position
You are asking about wing incidence? If so you need to set the incidence so that it neutral or slightly positive relative to the horizontal stabs incidence. Maybe .1 -.2 degrees positive incidence to start. I would set the plane up and level the horizontal stab both front to back and side to side, then set the wings incidence from there, as far a I know wing incidence should always be set relative to the stab.
Mike
