RE: V-MAR Beaver flight
one thing that will aggravate a tip stall is drooping ailerons. after setting up the ailerons normally. that is lined up with the hinge line. then adjust each aileron two turns on the clevis so the ailerons are raised that will give you some washout. sure beats trying to twist a wing panel. hope this helps.
