ORIGINAL: Schpankme
Regarding 2 vs 4 cycle engine, are we talking Methanol or Petrol (gas) ?
If you intend to use Methanol, do you intend to use straight FAI Fuel (Zero Nitro) ?
If you decide to run the Methanol/Nitro combined fuel, what percent of Nitro will you be requiring (5, 10 , 20 , 30 %) ?
Will you be wanting to use a Fuel Pump or Regulator ?
Will you be wanting to use electronic ignition or glow plug or other ?
What type of Oil have you decided to use - Synthetic, Mineral, Castor, Blended, POA/PAG (Ester) ?
Have you investigated your options for the type of Header and Tuned Pipe to use ?
Have you decided on the type of Engine Mount, and will you be needing a Nose Ring ?
Do you fancy planes with Cowls or Cowl-less ?
Should we discuss Electric as an alternative fuel [sm=drowning.gif]
_________
Schpankme
I think my brain just exploded........
-M
