The backfire as you are calling it, is likely from the engine loading up and dying rich. The 40 degree weather isn't helping. Go to the running instructions at
www.ysperformance.com and set the engine up properly. 3.5 turns open on the HS needle is way too far open. It should be at between 1.5 and 2 turns.
