RE: Rear Mounted Engines, how does it work?
Might it be a good candidate for a brushless electric motor? Put the batteries up front instead of lead. 3 blade prop on an outrunner type motor design. It would require cooling but maybe not as critical as a liquid power plant - put a small cooling fan on the same shaft as the prop. Jason Schulman (spelling?) certainly has pointed out the usefullness of the electric system (if you ignore the massive costs of batteries).
