RCU Forums - View Single Post - Real Flight G2 problem trying to hover.
Old 11-28-2004 | 12:09 PM
ez2bgman's Avatar
ez2bgman
Default RE: Real Flight G2 problem trying to hover.
shckscs,
I too had the same problems when I started practicing with the helis on G2. It took a couple of weeks to be able to hold a steady hover. Now I can hold a hover at any altitude, as long as I can maintain orintation. You can lose your orientation on G2 real quick.
Try learning tail-in hovering first. Once you have mastered that, then transition to nose-in hovering. You will learn that nose-in is a lot harder. All the control inputs are reversed.
Another thing, helis require constant input from all control services, including throttle/collective. They require a lot more concentration than fixed-wing aircraft. Most fixed-wing pilots no only 2 throttle settings, idle or wide open. Helis require constant throttle/collective inputs during an entire flight. Once you transition from a hover to FF, you will notice that the heli gains altitide due to transitional lift. Unless you want that, you would then have to adjust and take some throttle/collective out to maintain your hover altitude while in FF. It seems a lot harder than it actually is. Just keep practicing. Virtual helis are a lot cheaper than the real thing.
Goodluck and happy flying.
