RE: How does a Gyro work on Rudder Application?
Wow! What a reply! Thanks for the info. It sounds like the gyro is "working" all the time. It may not be something I want after all. I just want something that would quickly snap into action if I lost an engine. Maybe if I set the sensitivity low, it would'nt be working all the time? I definately don't like the idea of having to input rudder all the time to turn or do other things, although I guess I could couple the rudder and ailerons together to put everything on the right stick with the good old computer radio. I do plan on loops and rolls for the P-38, so that sounds like a tough problem to overcome, other than turning it off, then of course my "insurance" against flameout is turned off also. Thanks again!!
