RE: Which engine for Exta 300 special
The 3W 60 is a heavy engine so you think it would require to mount the servo's in the tail to get it to balance like with a G62. However, Brit (guy who posted in this forum) set his Extra Special with a 3W 60 and was able to use a pull-pull set up without adding weight to the tail. So if it worked with an Extra Special, would it work with an Edge?
