RCU Forums - View Single Post - Sceadu Evo servos????
Old 11-29-2004 | 06:06 AM
RCfun-RCU
Default RE: Sceadu Evo servos????
Just a thought.
Try add up the cost of all the equipment using standard or lower priced servos and then do the same using quality digital servos. In both cases the heli will cost quite a bit.
Looking at the relative cost difference the digital setup is not that much more expensive. Now ask yourself the question: What is the value of the extra security of going digital
(here I assume that for example F9252 servos wont break or fail as easily as standard servos)?
Personally I will rather spend around $1800 than $1600 (13% more) and then know that a servo failure is unlikely. Of course if the whole setup where only $400 (which unfortunately it is not) the
story will be different.
/RCfun
