Dave be sure and pin that wing back down to the board before you install the leading, and trailing edge sheeting. I usually completely finish one side of the wing before un pinning to make sure the wing stays straight. That wing will not be straight if you do not pin it back down. Also keep it pinned while you install the shear webs as well.
The last thing in the world you want is a wing with a big warp in it.
From your pics it looks like you are doing fine so far, so keep up the good work! After you build a few profiles you won't even need the instructions. I very briefly looked through my mojo instructions before starting.
Hey Razor, Send the new (60) kit to me. I can have it back to you ready for covering in a couple weeks. I'll build it for you pretty reasonable!
