RE: Suggestion for moderators
Actually, too much can hurt, in that it will tend to make the ailerons less responsive. That goes for high or low wing planes. If you put the wingtips at approximately the same height as the CG( somewhere in the middle of the fuse - say around the thrust line), that'll be at least neutral in roll.
