RCU Forums - View Single Post - Knife Edge Problem
Old 11-30-2004 | 11:49 AM
Wowbagger
Default RE: Knife Edge Problem
My Funtana used to tuck to the belly real bad in knife. It'd end up snapping out by the time you got enough correction on the elevator. Later on I had the wing dowels chew themselves out so I sleeved them with 10mm alloy tubing. When I opened out the holes in the bulkhead I filed away at the top of the hole only (towards the canopy). This gave about 1mm of extra wing incidence. It almost completely cured the tuck. I have 10% up elevator mixing with full rudder. One other thing I did was to reduce the rudder movement a bit. It was almost touching the elevators at full deflection before. Mine will hold a steady, no hight loss, knife for ever at half throttle now. Hope this helps you out.
Gez
