RCU Forums - View Single Post - Capiche 140 EX and IC version
Old 11-30-2004 | 05:04 PM
  #2134
Luke 3D returns's Avatar
Luke 3D returns
Default RE: Capiche 140
as far as exhaust goes i have the hatori 699 which is a sweet pipe. The only header that i know is compatible is the hatori cooling manifold.
As far as the mount goes i have the gator soft and safe mount, which is ok, but the rubbers need replacing about every 50 flights, which is a pain. If i could be botherd i'd have spent more initially on some flash mount which would do a better job.
Must admit the C140 will be sweeeeet with that 160DZ, just even more pricey to run and takes longer to fuel up!
