RCU Forums - View Single Post - Hovering and Gyros
Old 08-23-2002 | 09:37 AM
WreckRman2
Banned
Default Hovering and Gyros
Originally posted by R.Runyan
When it is 100 feet in the air, you can not see it well enough to do that, so you need to bring it down to at least 50 feet, you need a plane that will fall out and pull out quickly thats why the need for a good power to weight ratio is important.
50 feet? Bring that baby down to earth, more like 5-10 feet and have fun. If it does fall the closer you are to the ground the less damage it's gonna do. Besides, the airplane doesn't know it's that low.
If you want a really good 3D trainer build yourself a Morris Knife and put a Saito 72 on it. Don't buy the ARF because it'll be a pound heavier... Mine came out to 4lbs 3oz and it sure has taught me alot and YES it has hit the ground too...
Challenge yourself and the best way to do that is to bring as close to the ground as you can...
Tork It or Dork It!
