RCU Forums - View Single Post - solidworks
Thread: solidworks
Old 12-01-2004 | 04:30 PM
troyhm
Default solidworks
hi everyone
is there a way of drawing a three deminsion part in solidworks, then take cross section cuts at certain intervals to give the dimension of the formers. I need to create. I am only new at solidworks and havent worked out even how to do 3 demension shapes. The front former is different shape and size to the rear and I am trying to creat both out of balsawood with longerons attached to formers then covered in 1.5mm balsawood or use foam and cut out the under side of the foam as well and cover with 1.5mm balsawood. Or even trying another method I saw on here covering with brown painting paper. I will try all three to see which comes out lightest and strongest.
Troy
