RCU Forums - View Single Post - E-FLITE ULTIMATE,by GEORGE HICKS!
Old 12-02-2004 | 01:06 AM
  #51
pattern3dflyer
Default RE: E-FLITE ULTIMATE,by GEORGE HICKS!
Shogun,
Mine originally came out a little heavy because I used Hitech HS-56 servos (better choice would have been GWS PICO+F servos) I also used a Kokam 1500 3 cell and an old receiver with the case removed. The weight was over 15.6 oz and slowing down to a harrier made the wings a little rocky. I have since bought a smaller receiver and use TP 730mah packs and the weight is down to 12.6 oz. It now flys like a feather. It transitions from slow forward flight to harrier to hovering very smoothly. George Hicks intended that this plane weigh under 12 oz. It is way better the lighter it gets. If you trim the weight down and set the CG right you should be able to slow this plane way down as your confidence with it increases.
The CG on the plans may have been a little too far back. Just move it forward little by little so that when you fly inverted you do not need up or down elevator. This thing trims out perfect at the right CG.
I love this plane
