RCU Forums - View Single Post - PLEASE post some Pull-Pull Elevator Pics
Old 08-22-2002 | 02:01 PM
mecam's Avatar
mecam
Default Re: Pull Pull Elevator
Originally posted by jatt5abdaa
Thank you mecam.
I was planning this setup for the AW Edge 60/90.
Some questions though...
1) Are the 2 servos for each elevator half or can you use one servo for both elevators ?
2) Can you lay the servo on it's side coz unless the servo sits dead center, one wire will be longer than the other one.
Thanks.
1) You can use either 1 or 2 servos. Get the highest torque if you are only using one.
2) Servo does not have to be dead center. You adjust the wire length accordingly. Also servo does not have to be on it's sides. I would use some kind of antenna tube at the exit hole of the fuselage to make the wire run smooth.
