RCU Forums - View Single Post - Why learn with a FLOATER
Old 12-02-2004 | 05:05 AM
Bob101
Default RE: Why learn with a FLOATER
My hunch is that all those EDGES, CAPS, etc. have a better take-off and landing personality that our KITES w/engines.
Would you like to translate this into understandable English or something which loosely resembles what you actually meant to say?
If you are trying to suggest that it's easier to land the above, then you would not only be wrong, but indulging in an overgeneralisation. Depending upon individual design, especially wing loading and whether washout has been built into those Edges and Caps, they require superior skills to consistantly approach on speed and land accurately and safely - which is why so many barely in control idiots choose to approach and land way too hot.
The rules of physics and aerodymics remain the same for both. Technique and finesse required are derived of an understanding of these in conjunction with accomplishent through discipline and practice of those.
I disagree, just because it's different doesn't make it more difficult. An extra/edge/cap that is properly set up lands itself much more so than a trainer ever will.
Just because you have to keep the throttle to a point where the plane continues to fly doens't make it more difficult - just different. I've seen many students struggle with a trainer do to the plane wanting to float on a calm day - and pushing a plane over to get it down on landing is a bad habit that will rear it's ugly head if the student ever progresses past trainers.
Once properly set up a plane with aerobatic ability is a joy to land. Point it into the wind, keep just enough power to keep it from falling out out of the sky and it will have a slow gentle descent and all that is required is to cut the power the last 1 foot and watch the most beuatiful landings ever.
I'd say it's much easier to get it lined up and keep the power up and cut on the runway and much quicker to learn, than knowing that you have to X feet high on the downwind and knowing where to cut the power before you even turn base.
Just a matter of opinion, but I never understood learning to fly on a plane that doesn't fly like any other plane your likely to fly after that. It only teaches bad habits, like stick banging etc...
