RE: RYOBI
Typically, a cheap whacker crank is not a forging. There is the main shaft, the counter weight, the and crank pin. They are just pressed together. They work fine in normal use. The Mac 32's are bad about the crank pin working out and rubbing a hole in the back plate.
Jim
